Author Topic: Writing Reports with Tables  (Read 6755 times)
davidson
« on: September 12, 2016, 03:18:28 pm »
Sorry Everyone,
I see be asking questions on every step of my journey. Firstly does anyone know if there is a user guide on writing reports in Sparx?
i have searched around and cannot find anything.
The problem I am about to describe has been suggested "you can do it" in the Web site, but doesn't give any examples how to do it.
I have a very simple request.
I have created a custom SQL query that returns 3 columns in the following foramat :
Diagram name         Element name   Dependancy Name
Diagram 1                   Element 1             Depend1
Diagram 1                   Element 1             Depend 2
Diagram 1                   Element 1             Depend 3
Diagram 2                   Element 2             Depend 5
and so on.
All I want to do is turn the above into
        Depend 2
        Depend 3
With some form of alternative colour for rows for each new diagram name change, and a Header.
I thought the merge row might do this, but unclear how it works.
I have 1 row set up for the table with these fields. I have tried "merge row for the first and second" but nothing happended.
I tried creating another row and merge the two, but that just duplicated.
I am totally unclear as tow how this is supposed to work.
Also how do I get alternative colours rows?
RoyC
  • Read The Help!
Re: Writing Reports with Tables
« Reply #1 on: September 12, 2016, 03:45:51 pm »
Best Regards, Roy
« Reply #2 on: September 12, 2016, 06:32:01 pm »
Some of the things you are asking seem simple, but are (almost) impossible AFAIK.
Alternating colors is one of these things.
There might be a simple Word Macro that might solve that for you.
As for your table, you'll have to make sure that your query returns two rows instead of  4
One for the combination of Diagram1/Element1, and one for the combination of Diagram2/Element2
Then in the dependency name make sure to add add dependencies, concatenating them with newlines if needed.
davidson
« Reply #3 on: September 13, 2016, 03:10:25 pm »
This is so frustrating - trying to do something, find a complexed , second rate workaround.
Now something as mundane as trying to remove numbers from a Heading for an appendix is turning into all day challange.
I give up, I'm going back to cutting and pasting the whole freaking thing, certainly more time-saving
« Reply #4 on: September 13, 2016, 03:58:34 pm »
I feel your pain; been there, done that, got the T-shirt :'(
Regarding the numbers and headings, the Stylesheet is your savior.  Editing styles in the style sheet is somewhat of a dark art, but you only have to do that one time. Once you have the styles in the stylesheet you need, you can apply them anywhere in the documents.
Changing a certain style then only needs to be done in one place.
It might save you a bit of frustration (or even money seeing the time you already spent on the project) to hire a consultant to do the initial setup properly.
Once you are there modifying existing well working templates is a lot easier than starting from scratch.
There's a list of registered consultants (Sparx calls us "Value Added Resellers") on the Sparx website: http://www.sparxsystems.com/partners/vars.html I'm sure you'll find one that is close to where you work that can come in for a day to kickstart your docgen template project.
It's worth it in the long run... :-\
davidson
« Reply #5 on: September 13, 2016, 07:51:37 pm »
Thanks Geert.
I shall look them up!
