Author Topic: Task Scheduler  (Read 14544 times)
msdb
Task Scheduler
« on: September 12, 2016, 06:12:03 pm »
Hi
I've written a C# console program that uses the EA Api to access a repository and export an xmi file. I'm trying to make this program run automatically on a windows server 2008 with the task scheduler which works fine when I'm logged on to the server, however, I'd like it to be able to run when I'm not. This doesn't seem possible though, no matter what settings I use. Thus far, I've assumed that windows was the problem, not EA.
Has anyone tried something similar or know whether EA is unable to be launched without a logged in windows user?
Re: Task Scheduler
« Reply #1 on: September 12, 2016, 06:16:34 pm »
This is a know issue.
The easiest solution is to make it run with an actual user logged in.
Apparently the guys from LieberLieber managed to get it running as an actual service, but haven't heard anyone else being able to reproduce their result.
See http://blog.lieberlieber.com/2012/09/03/ea-as-an-unattended-windows-service-on-windows-server-2008r2-and-higher/ for more info
OpenIT Solutions
Re: Task Scheduler
« Reply #2 on: September 12, 2016, 07:15:18 pm »
I don't think you need to follow the steps in the article that Geert refers to IF you are attempting to run your c# app via the Task Scheduler. Just make sure that the user account you use (you can set an explicit user for a Task) has a) run Sparx on the server - so the license has been set and b) has full permission to write to the file system, connect to sparx and use a network connection.
I have a c# app that runs via the task scheduler each night and generates html via Sparx API. So it should work.
Jon.
Re: Task Scheduler
« Reply #3 on: September 12, 2016, 09:07:58 pm »
Jon.
If indeed you can specify a "real" user in the task that might be enough to work. Of course you'll need to have EA installed on the server as well.
msdb
Re: Task Scheduler
« Reply #4 on: September 12, 2016, 11:21:34 pm »
Thank you both for replying.
I've tried what you suggest. EA is installed on the server and a user has been specified for the task. When I log back in to the server I can see that EA.exe is running, so it has been launched but no export occurs.
I have also given the user full write/read access to the export folder and where EA.exe is located. Not sure what else I can do.
Re: Task Scheduler
« Reply #5 on: September 12, 2016, 11:35:14 pm »
I have a client that has the scheduled task running on a spare pc somewhere under a desk (with a sticker "Don't ever turn off!")
Re: Task Scheduler
« Reply #6 on: September 12, 2016, 11:35:37 pm »
It still sounds as if you launch it as service. That does not work. You need a real login and a console. Consider a Citrix environment where you can disconnect a user.
OpenIT Solutions
Re: Task Scheduler
« Reply #7 on: September 13, 2016, 02:18:32 am »
Have you actually logged in as the user on the server and started Sparx ? You need to do this so the license is correctly assigned to the user on their first run of EA. If you don't do this when connecting to Sparx API via a scheduled task - you will get the behavior you observe, ie Sparx will be running, but not doing anything - as what is actually happening, is that Sparx has started up under the users accounts/session and is waiting for them to enter their license key.
Jon.
Dani_baer
Re: Task Scheduler
« Reply #8 on: December 14, 2016, 02:21:35 am »
Hi
Is there a solution to this problem?
thanks
Re: Task Scheduler
« Reply #9 on: December 14, 2016, 03:05:30 am »
Yes, log in, make sure EA runs when started manually, then create a scheduled task under the same user and make sure that user is always logged on the machine that has the scheduled task.
Not ideal, but it works.
IIRC there are also tools and/or settings to make sure a certain user is automatically logged in when the computer reboots.
Glassboy
Re: Task Scheduler
« Reply #10 on: December 14, 2016, 11:36:01 am »
The user account you are using has to have permissions to log on and run applications.  From memory the local policy has to include "Log On Interactively" for that user.
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: Task Scheduler
« Reply #11 on: November 24, 2018, 08:13:29 am »
We have developed some apps (as windows services) that work in the server-side. There are many considerations to make them work, and we have developed them as standard apps that maybe could fit your needs. Check our forum signature to view the options.
All of them works in the following environment:
  • Server-side
  • Windows server 2008 R2 SP1 (not tested in equivalent or similar environments)
  • Server must have EA installed and a standard license set (not floating). Tested with EA v 13.0
  • Could work in EAP files, databases or Cloud Server
  • And the most important: they work even when there is no user session active in the server!
As they work as Windows Services, they could be customized to execute some tasks periodically (as create baselines, create connectors, send emails, update diagrams, etc).
Feel free to ask if need more info
