Author Topic: Problem with updating DiagramObject position  (Read 4714 times)
Eamonn John Casey
« on: September 20, 2016, 06:49:02 pm »
I got a problem when updating the size and position of DiagramObject using the API.
I have a Boundary object and that code works just fine. But then I try placing (for example an ArchiMate element). The same code will not move the element properly.
Attempt 1:
private void UpdateElementOnDiagram(
EAAPI.Diagram diagram, EAAPI.DiagramObject diagramObject,
int left, int right, int top, int bottom)
diagramObject.top = top;
diagramObject.left = left;
diagramObject.bottom = bottom;
diagramObject.right = right;
diagramObject.Update();
Attempt 2:
String styleString = diagramObject.Style.ToString();
String[] styleList = styleString.Split(';');
for (int nIndex = 0; nIndex < styleList.Count(); nIndex++) {
if (true == styleList[nIndex].Contains("l=")) {
styleList[nIndex] = String.Format("l={0}", left);
} else if (true == styleList[nIndex].Contains("r=")) {
styleList[nIndex] = String.Format("r={0}", right);
} else if (true == styleList[nIndex].Contains("t=")) {
styleList[nIndex] = String.Format("t={0}", top);
} else if (true == styleList[nIndex].Contains("b=")) {
styleList[nIndex] = String.Format("b={0}", left);
styleString = String.Join(";", styleList);
diagramObject.Style = styleString;
I also do the Diagram.Update()
Any ideas?
Eamonn J.
Re: Problem with updating DiagramObject position
« Reply #1 on: September 20, 2016, 07:29:04 pm »
After updating the diagramobject make sure you refresh the diagram.
Saving the diagram might have an adverse effect and undo the changes you just made.
Also remember that the Y axis is negative starting from 0 at the top.
Eamonn John Casey
« Reply #2 on: September 20, 2016, 08:45:00 pm »
I used Attempt 1 and negated the top and bottom values and now it Works as expected.
EjC
