Author Topic: Shape script - connector line type  (Read 6628 times)
harvinder
« on: May 03, 2011, 12:08:17 pm »
Following is the shape script that I have used for dependency
shape main
    noshadow=true;
    setlinestyle("solid");
    moveto(0,0);
    lineto(100,0);
As long as the connector is straight I see solid line. However, when I break the connector I would see dashed line.
Okay
Source _______________Destination
Not so okay
Source
Re: Shape script - connector line type
« Reply #1 on: May 03, 2011, 04:31:34 pm »
This is a known bug...
I can't remember if v9 Beta fixed it or not...
adama
Re: Shape script - SOLID connector line type does not work in v13
« Reply #2 on: February 26, 2017, 04:42:26 am »
This bug is NOT fixed. Take any dashed line and try to make it solid with an EA script. Only the horizontal segments are solid; vertical segments are invisible.
A_________>B works fine
      A
      B does not work. Vertical portion is invisible
A____
          ____>B does not work correctly. Vertical portion is invisible
« Reply #3 on: February 27, 2017, 10:16:44 am »
      A
A____
Works for me (stereotyped Dependency using harvinder's shape script from the first post in this thread). What version of EA 13 are you using? What base connector type are you extending? What is your shape script? Line style? Diagram type? Source and target elements?
adama
« Reply #4 on: March 09, 2017, 02:00:21 am »
Yep. It works. Obviously, some operator error over here. Thanks MUCH to KP and others.
