Author Topic: Sample for creating a structured scenario from C#  (Read 4141 times)
Colin Richardson
« on: March 16, 2011, 06:32:36 pm »
Hi All,
I'm having troubles creating a structured scenario for a use case.
I've got all the scenarios in place, but I'm just not getting the ScenarioExtensions to save.  The step's extensions collection has a count of 1 in the code, but afterwards, can't find any trace in the scenario editor, or in the database  >:(
A nice little working sample would be wonderful if someone has one...
~ Colin
Colin Richardson
Re: Sample for creating a structured scenario from
« Reply #1 on: May 05, 2011, 09:21:12 am »
Should've posted this earlier.
Here's a sterilised version of what I ended up creating.  Be warned this sterilised version hasn't been tested - use at own risk.
 private void insertBasicPath(string name)
            var scenario = (Scenario)_selectedUseCase.Scenarios.AddNew(name, "Basic Path");
            scenario.Update();
        private void insertBasicPathStep(Scenario scenario, int position, string text)
            ScenarioStep step;
            if (text.ToUpper().StartsWith("ACTOR"))
                step =
                    (ScenarioStep)
                    scenario.Steps.AddNew(text.Trim(), "1");
            else
                step =
                    (ScenarioStep)
                    scenario.Steps.AddNew(text.Trim(), "0");
            step.Pos = position;
            step.Update();
            scenario.Update();
            scenario.Steps.Refresh();
        private void insertConstraint(string text, string type)
            var constraint = (EA.Constraint)_selectedUseCase.Constraints.AddNew(text, type);
            constraint.Update();
        private List<Message> insertAlternateCourse(string name, List<string> steps, short varies, short? rejoins)
            var messages = new List<Message>();
            _selectedUseCase.Scenarios.Refresh();
            _selectedUseCase.Update();
            var scenario = (Scenario) _selectedUseCase.Scenarios.AddNew(name, "Alternate");
            scenario.Update();
            // create the varies and joins!
            Scenario basicPath =
                _selectedUseCase.Scenarios.Cast<Scenario>().FirstOrDefault(
                    thisScenario => thisScenario.Name == "Basic Path");
            if (basicPath == null)
                messages.Add(new WarningMessage("Unable to find basic path"));
                return messages;
            // varies from
            short variesStep = varies;
            if (variesStep <= basicPath.Steps.Count)
                var basicPathVariesStep = (ScenarioStep) basicPath.Steps.GetAt(varies);
                var extension =
                    (ScenarioExtension)
                    basicPathVariesStep.Extensions.AddNew(scenario.Name, scenario.ScenarioGUID);
                //rejoins at
                if (!rejoins.HasValue)
                    extension.Join = "End";
                else
                    var basicPathJoinStep = (ScenarioStep) basicPath.Steps.GetAt(rejoins.Value);
                    extension.Join = basicPathJoinStep.StepGUID;
                extension.Update();
                basicPath.Update();
            else
                messages.Add(
                    new ErrorMessage("Step " + variesStep +
                                     " does not exist in the basic flow. Alternate course not created for '" +
                                     name + "'"));
            var stepPos = 1;
            foreach (var step in steps)
                var scenarioStep =
                    (ScenarioStep)
                    scenario.Steps.AddNew(step, "System");
                scenarioStep.Pos = stepPos;
                scenarioStep.Update();
                stepPos++;
            scenario.Update();
            return messages;
