Author Topic: Repository.ImportTechnology does not work  (Read 4247 times)
stao
« on: June 09, 2011, 12:37:38 am »
i have a problem to use this method correctly.
iam using EA from an extern program so i cant use the OnInitializeTechnology method to inject my mdg file.
repository = new EA.Repository();
          bool val = repository.ImportTechnology(Properties.Resources.techFile);
the techfile string contains the xml data of the mdg technology.
the returnvalue is always false.
where is my mistake?
Re: Repository.ImportTechnology does not work
« Reply #1 on: June 09, 2011, 08:59:57 am »
OnInitializeTechnology  is called before a model is loaded.
ImportTechnology imports the technology into the current model.
You should return your xml from OnInitializeTechnology.
