Author Topic: How to create TOGAF add-in element with script?  (Read 5574 times)
AlexY
« on: June 20, 2011, 10:19:39 pm »
QUESTION: I want the elements created by script to have TOGAF add-in properties. How can I do this? Thanks.
(Background information is below).
I use TOGAF add-in and need to import many elements representing physical application components.
The TOGAF add-in has a special element "PhysicalApplicationComponent" in toolbox intended to represent physical application - see image below..
The element has a set of TOGAF properties defined as tags - see the image below..
When add elements with script:
var thePackage as EA.Package;
var elements as EA.Collection;
var element as EA.Element;
thePackage = Repository.GetTreeSelectedPackage();
elements = thePackage.Elements;
element = elements.AddNew( "Created by script", "Component" );
element.Stereotype = "PhysicalApplicationComponent";
The element created does not have TOGAF properties..
So, how to create an element which will have the TOGAF properties as defined by the TOGAF add-in?
Luis J. Lobo
  • IT Consultant
Re: How to create TOGAF add-in element with script
« Reply #1 on: June 20, 2011, 11:51:03 pm »
Change the line:
to:
element = elements.AddNew( "Created by script", "TOGAF::PhysicalApplicationComponent" );
« Last Edit: June 20, 2011, 11:51:26 pm by Deiser »
AlexY
« Reply #2 on: June 21, 2011, 12:56:32 am »
Yes, it worked! Thanks, Luis.
