Author Topic: How to create Note Elements and Links  (Read 4066 times)
VibroLarynx
« on: June 16, 2011, 07:15:55 pm »
I could not find a related topic in the forum and also not in the help file. So my question is:
How is it possible to create (using the automation interface) Note Elements and attach normal elements with Note elements via the NoteLink?
VL
« Last Edit: June 16, 2011, 07:16:49 pm by VibroLarynx »
Re: How to create Note Elements and Links
« Reply #1 on: June 16, 2011, 10:38:47 pm »
VL,
Should be possible.
I think notes are just another type of Elements, so you should be able to create just like any other type of Element.
I guess the same thing will be valid for the connector.
abruckner
« Reply #2 on: June 17, 2011, 04:38:39 pm »
Links in Notes are just done by Hyperlinks containing the elementGuid. Tricky thing is: if you rename the element, the displayName in the link is _not_ updated.
And I did not find a single EA menu entry, to update them.
VibroLarynx
« Reply #3 on: June 21, 2011, 06:38:00 pm »
Thanks for the information!
