Author Topic: Macro expansion in GenPath  (Read 3365 times)
AndreasKo
« on: June 22, 2011, 01:43:53 am »
Hi all,
I have a VB script that sets the Genfile attribute of an element to specify the file name for code generation:
currentElement.Genfile = BASE_PATH & "\" & currentElement.Name & ".java"
How can I use a macro in BASE_PATH so that each developer can set it to their own local directory? From the EA users guide (search for macro expansion in EA help):
GenFile : String : Read/Write. The file associated with this element for code generation and synchronization purposes. Can include macro expansion tags for local conversion to full path.
Can I use the "Default Source Directory" from the Options dialog (Tools/Options/Source Code Engineering/Java) in BASE_PATH?
Tried a field substitution macro but it didn't work:
const BASE_PATH = "%genOptJavaDefaultSourceDirectory%\MyProject\src\main\java\com\mycompany"Seems like these can only be used in code generation templates, not in VB scripts operating on the model.
Andreas
« Last Edit: June 22, 2011, 02:06:06 am by AndreasKo »
Re: Macro expansion in GenPath
« Reply #1 on: June 22, 2011, 08:19:54 am »
See Local Paths in the help.
AndreasKo
« Reply #2 on: June 22, 2011, 05:23:51 pm »
Simon,
it works!
I entered a new local path "CodeGenPrefix" with type Java and my local path s:\svn_src. And clicked Apply path. Now I replaced my earlier definition in my VB script to:
const BASE_PATH = "%CodeGenPrefix%\MyProject\src\main\java\com\mycompany"
When generating code with code engineering after running my script, I now get this prefix replaced with my local path.
Andreas
