Author Topic: behaviour with splitting connectors  (Read 3353 times)
stao
« on: June 29, 2011, 08:00:51 am »
Hi all
i discovered some weird behaviour while splitting connectors using strg + mouseclick.
i created an uml profile with a connector stereotype and a shapescript.
for some reason one part of the splitted connectors is now dashed and black although it should be solid green as you can see in the attached picture.
any ideas how this can be solved?
gz
stao
« Last Edit: June 29, 2011, 08:01:08 am by stao »
Re: behaviour with splitting connectors
« Reply #1 on: June 29, 2011, 08:21:38 am »
First step is to get the latest build of EA.
If that doesn't work, then you'll need to provide the shape script in a bug report using the link at the bottom of this page.
