Author Topic: Hyperlink options  (Read 4574 times)
progress
Hyperlink options
« on: September 23, 2016, 11:00:49 pm »
In EA it is possible to insert HTML links. This works fine, but doesn't cover all needs. For instance in a class model we want to make  a class clickable in a diagram opening a web URL. That way want to link our objects in EA with documents existing outside the EA repository. Is there a way to enable this?
PeterHeintz
Re: Hyperlink options
« Reply #1 on: September 23, 2016, 11:10:21 pm »
AFAIK this is not possible. What I do in those cases is adding the link in the Properties dialog under Related/Files.
However to open that link it is not a “one-click”.
Best regards,
Peter Heintz
Uffe
« Reply #2 on: September 28, 2016, 09:37:19 pm »
You can't do this with the basic EA funcitonality, but it's simple enough if you write an Add-In.
Add a handler for EA_OnContextItemDoubleClicked() which launches the browser. Easy peasy.
/Uffe
« Reply #3 on: September 29, 2016, 12:27:11 am »
Or use EA-Matic and write a script
PS. Or even better: pay Uffe or me to solve the problem for you 8)
