Author Topic: High level system diagram  (Read 8136 times)
PhilJollans
« on: September 24, 2016, 06:53:47 am »
I would like to make a high level and fairly informal system diagram.
I want to include:
- software components
- hardware components
- maybe mechanical systems
- files
- possibly a database
- actors
I don't really care if it a formally correct UML diagram.
Can I make a diagram like this using Enterprise Architect, and if so, what kind of diagram would it be?
Thanks in advance
Phil
mackie
Re: High level system diagram
« Reply #1 on: September 24, 2016, 07:28:55 am »
You might consider ArchiMate for this kind of thing.  It will take some time to learn it though, so if you need to crank out something in the next hour this isn’t the solution for you.
Stephen Kropp
« Reply #2 on: September 24, 2016, 07:35:29 am »
Have you checked out the demo videos available on the Sparxsystems website, they are very good and could be pieced together to get what you need?
http://www.sparxsystems.com/resources/demos/
« Reply #3 on: September 24, 2016, 08:08:40 am »
You can also have a look into EA's example model. Help/Example Model
Glassboy
« Reply #4 on: September 24, 2016, 10:18:18 pm »
I want to include:
- files
- actors
That's not what I'd call high level, but a UML deployment diagram can be used to do what you want.  Just add stereotypes to the components and nodes to indicate what they are, and drop and actor in from the use case tool toolbox.
PeterHeintz
« Reply #5 on: September 26, 2016, 06:20:23 pm »
If you want to have software, hardware and mechanical stuff in you model SysML could also be a good choice because modeling these things together is what SysML is all about.
Best regards,
Peter Heintz
PhilJollans
« Reply #6 on: September 26, 2016, 10:26:13 pm »
Thanks for the answers.
I have made a diagram which is good enough as a Deployment diagram. I had previously not found the "more tools..." option in the toolbox, so I couldn't figure out how to add actors to a diagram which was not a use-case diagram.
The Example Model is a good source of ideas which I will refer to in future.
SysML and ArchiMate both look interesting. Our team has a license for Enterprise Architect, so I wanted to use this tool if possible.
Phil
