Author Topic: Actors in a BDD  (Read 16251 times)
Stephen Kropp
Actors in a BDD
« on: September 24, 2016, 07:21:29 am »
Can anyone help me understand the finer details of a BDD, I'm trying to understand if I can add an Actor to a BDD instead of creating a block for the same actor? EA appears to let me add Actors to a BDD but is there a reason why I shouldn't do this?
I have been using "A Practical Guide to SysML" by Friedenthal et al. for reference but all of the examples from that book are using blocks.
Steve
PeterHeintz
Re: Actors in a BDD
« Reply #1 on: September 26, 2016, 06:30:11 pm »
Yes SysML allows you to put Actors on a BDD.
What to use when, depends on what you want to achieve or is even sometimes a matter of taste.
If I want to show that e.g. a person is acting from outside with a system I typically use an actor. If e.g. the person is part of the system, I typical use a block to represent the person.
Best regards,
Peter Heintz
Stephen Kropp
Re: Actors in a BDD
« Reply #2 on: September 27, 2016, 12:29:31 am »
I try to not have duplicate items within the model representing the same thing so it bothers me that I have to make a separate swimlane for my actors and that it appeared that I needed to make, yet another block for the actors too.
Thank you!
PeterHeintz
Re: Actors in a BDD
« Reply #3 on: September 27, 2016, 12:59:33 am »
Why do you need to make separate swim lanes?
As I have said, you do not need to duplicate actors.
As long as the language capability of an UML/SysML actor is sufficient for you, use the UML/SysML actor.
If you need more language capabilities to describe the “concrete actor”  you can use e.g. a Block or a Class to do that, instead of using an UML/SysML actor.
If you want to have it duplicate for some reasons you can do that as well, but in this case I would put those in a relation to state the both are the same.
Best regards,
Peter Heintz
Stephen Kropp
Re: Actors in a BDD
« Reply #4 on: September 27, 2016, 01:34:11 am »
Thanks for the clarification. I didn't fully explain my response before. I was simply using examples of things that I (think I need to) duplicate using SysML and was including a block representing an actor as one of those items. I am glad to see that I don't need to do this.
So in your example, since you use blocks if the actor is part of the system, you relate a use case to a block in the same way you would relate a use case to an actor?
Is there a better way to relate an actor to a swim lane other than just putting the actor in the swim lane?
Thanks for your help!
Re: Actors in a BDD
« Reply #5 on: September 27, 2016, 01:40:33 am »
Usually a swim lane is just a graphical element on a diagram and you should not use them since they do not really add semantics to the model. Instead use pools/lanes and classify them with your actor. They are real elements and you can put other elements inside which participate in activities.
« Last Edit: September 27, 2016, 02:33:08 am by qwerty »
PeterHeintz
Re: Actors in a BDD
« Reply #6 on: September 27, 2016, 01:54:17 am »
Regarding your use case to block connection question, yes I relate a block in the same way as an actor.
For swim lane stuff see response from qwerty.
Best regards,
Peter Heintz
