Author Topic: adding attributes in profiles  (Read 23832 times)
Ted Speers
« on: September 27, 2016, 01:34:33 pm »
I want to create a class stereotytpe that when I pull it into a diagram, it has the attributes and methods already attached.  The documentation only shows how to add tags to a  stereotype (I have no idea what good tags are BTW ... would love to be enlightened).
The behaviour i want is found in the ArcGIS toolkit .
When a <<CodedValueDomain>> is added to a diagram, it has attributes ... 3 of which have nothing to do with the Profile.
Re: adding attributes in profiles
« Reply #1 on: September 27, 2016, 02:02:19 pm »
The way I would do this, and the way it has been implemented in ArcGIS, is as follows:
  • Create a profile with your stereotype. Save it.
  • Create an MDG Technology that includes your profile. Let the Technology Wizard create a .MTS file so you can rebuild the technology later.
  • Deploy the MDG Technology.
  • Create a stereotyped element on a diagram. Give it all the attributes and operations you want it to be created with.
  • Save the diagram as a Pattern.
  • Create a toolbox profile. One of the toolbox commands will be "MyTechnology::MyPattern(UMLPatternSilent)". Save the toolbox profile.
  • Rebuild your technology, including the Pattern and the Toolbox Profile.
  • Re-deploy your technology.
Instructions for each step can be found in the help file. Good luck!
« Last Edit: September 27, 2016, 02:24:17 pm by KP »
Ted Speers
« Reply #2 on: September 28, 2016, 12:09:01 pm »
thanks ... it wasn't obvious
« Reply #3 on: September 28, 2016, 04:41:39 pm »
Hi Ted,
When you get it working, can you post the relevant snippet(s) of the MDG?  I'm interested in seeing the effects of the process on the output MDG.
TIA,
Ted Speers
« Reply #4 on: October 03, 2016, 06:13:21 am »
Just got around to it and haven't been able to get it working.
When I drag the pattern onto the diagram, it says 'Pattern not found in model's resources.'
I am definitely including the pattern in the MDG build wizard.
In the toolbox ... I'm naming the attribute TechName::PatternName(UMLPatternSilent) where
- TechName is the name I enter in the first line "Technology" in the MDG wizard and
- PatternName is what i call the pattern in the save as  UML pattern dialog.
BTW, if i right click on 'Pattern' in the model resources box, i do not get an option to import a pattern.  I don't think importing is necessary if it is included in the MDG build dialog.
Using EA v11
« Last Edit: October 03, 2016, 08:26:43 am by Ted Speers »
« Reply #5 on: October 03, 2016, 07:27:26 pm »
Patterns are NOT included in the MDG file (unfortunately) and have to be distributed separately.
There's a discussion from a few months ago about this specific shortcoming of MDG's
Ted Speers
« Reply #6 on: October 04, 2016, 12:10:56 am »
Can you tell me how to modify the procedure supplied earlier in this thread?  Does the fact that I can't appear to import patterns cause an issue?
<copied from above>
« Reply #7 on: October 04, 2016, 12:29:59 am »
Ted, the "redeploy your technology" step has to include distributing your pattern xmi to a specific location (I don't remember exactly where)
Ted Speers
« Reply #8 on: October 04, 2016, 03:24:20 am »
so this thread ( http://sparxsystems.com/forums/smf/index.php/topic,30878.msg224230.html#msg224230 ) refers to putting stuff in this directory ... C:\Program Files (x86)\Sparx Systems\EA\ModelPatterns
will give that a try
Ted Speers
« Reply #9 on: October 04, 2016, 06:05:22 am »
didn't work
« Reply #10 on: October 04, 2016, 06:45:24 am »
I know this does not sound quite helpful, but sleeping a night over it did solve such issues for me in most cases. Usually it was a simple typo or I saved the wrong date in the wrong place (double the error!). Yes, EA is very unforgiving when it comes to errors in MDG creation. You just get a "does not work" and no hint what might be wrong. If sleeping over it did not solve it, start over with a tiny sample and grow that stepwise (!) until it has everything you need.
Ted Speers
« Reply #11 on: October 04, 2016, 02:24:11 pm »
haven't quite slept on it ... did inspect the .xml file generated by the wizard ... i'd attach it if i could
in the xml the data structure is
<UMLPatterrns>
    <UMLPattern>
    ---- from the pattern file ...named after the drawing
    </UMLPattern>
    <UMLPattern>
    ---- from the MDG generation wizard ... name = MyName
    </UMLPattern>
</UMLPatterns>
in the toolbox, i tried both names ... drawing name in first UMLPattern tag and name in second tag ... both give same error when i drag it from toolbox onto a drawing.
« Reply #12 on: October 04, 2016, 02:38:11 pm »
It's the technology ID, not name. The second line of your technology will be something like this:
  <Documentation id="GoF" name="Gang of Four Patterns" version="2" notes="Use patterns from the book Design Patterns by Gamma, Helm, Johnson and Vlissides." infoURI="http://www.sparxsystems.com" supportURI="[email protected]"/>
In this case, it will be "GoF" that you need to use, not "Gang of Four Patterns".
« Last Edit: October 04, 2016, 02:41:22 pm by KP »
Ted Speers
« Reply #13 on: October 05, 2016, 01:28:09 am »
that works, thanks
« Reply #14 on: October 05, 2016, 10:34:35 am »
that works, thanks
Hi Ted,
That's great!  Just so there's no confusion, can you post a snippet?
TIA,
