Author Topic: to get collections of all diagrams in the model  (Read 5822 times)
sspvirgo
« on: July 16, 2011, 06:31:08 am »
I am not able to get the collections of diagram in the model. if there are many packages in the model  i can get the collection of diagram of individual package  from package.diagrams attribute but what i need to do if i want the collections of all diagrams in the model. I need to store that in my collection class so that i can use that in future.
Appreciate your help
Saddiq Prasla
Re: to get collections of all diagrams in the mode
« Reply #1 on: July 19, 2011, 04:41:48 pm »
The best way to go about is to use an sql query with Repository.SQLQuery() to get all id's of all diagrams, and then use Repository.GetDiagramByGuid() to get the actual diagram.
PS. Are you sure you need ALL diagrams? That might be quite a performance hit.
sspvirgo
« Reply #2 on: July 20, 2011, 02:31:10 am »
Hi Geert,
Thanks you for the solution.
I need to have collection of diagram as i need to perform checks on every diagram. Also the getDiagramByGUID requires string GUID from where i would get this parameter. You told if i query i would get list of Ids and  IDs and Guid are differerent.
What i am thinking of your solution is: correct me if i am wrong
I would get the diagram Guid by iterating through all the diagram using diagram class object using DiagramGUID Attribute and then i would store that and get the diagram by passing the GUID
« Reply #3 on: July 20, 2011, 04:30:32 am »
No,
You use an sql query to get a list of all guid's of all diagrams ("select diagramguid from t_diagram"). You loop over each of those guid's and use Repository.GetDiagramFromGUID to get the actual diagram objects.
sspvirgo
« Reply #4 on: July 20, 2011, 05:53:00 am »
Hi Geert,
When i am querying using sql query i am getting an error two few parameters. Expected 1. This is what i wrote repository.sqlquery("Select diagramguid from t_diagram")
Thank you
« Reply #5 on: July 20, 2011, 10:23:02 am »
Try:
SELECT ea_guid FROM t_diagram
sspvirgo
« Reply #6 on: July 20, 2011, 11:55:59 pm »
Thanks it is working fine. However I am getting the string with XML format so do i need to parse that as an XML and get the GUID of all diagram is that correct.
« Reply #7 on: July 21, 2011, 12:08:15 am »
yes
