Author Topic: Generate Documentation Options - Skip Root Package  (Read 4165 times)
Stephen Kropp
« on: October 04, 2016, 06:52:39 am »
I am trying to use the Generate Documentation feature efficiently and am finding that I am using the "Skip root package" option for every report that I want to generate. Is there any way to auto-select this option without having to select it each time?
Stephen Kropp
Re: Generate Documentation Options - Skip Root Package
« Reply #1 on: October 04, 2016, 08:04:03 am »
I figured it out! If anyone else is wanting to do this here are the steps:
1) I had to create a new template:
  • Right-click on a package, select "Documentation"
  • Select "Generate Documentation"
  • Select "Templates" (from the left tree of options)
  • Select "New"
  • Give the template a name
  • Select the template you wish to modify from the "Copy Template" drop-down)
2) Modify the newly created custom template
  • Right-click anywhere on the template"
  • Select "File"
  • Select "Document Options..."
  • Select the options you want, in my case I selected "Skip root package"
3) Select the custom template for generation
  • Right-click on the package you want to document, select "Documentation"
  • Select "Template:" drop-down option and select your new custom template
  • Select "Generate"
* One note, I tried doing this same procedure to a style sheet template but the process didn't work, it appears that the Document Options need to be selected at the root template that you are using from the Generate Documentation dialog box.
« Last Edit: October 04, 2016, 08:09:59 am by Stephen Kropp »
