Author Topic: to check whether usecase is icluded or extended  (Read 4279 times)
sspvirgo
« on: July 21, 2011, 06:52:05 am »
I want to see whether my use case is included use case or extended use case when i am checking with the connectors.type i am getting the value as Usecase for both the included and extended use case. How would i know which one is the included use case and which is extended.
Appreciate your help on this.
Re: to check whether usecase is icluded or extende
« Reply #1 on: July 21, 2011, 03:27:19 pm »
I'm guessing, but probably the usecase on the target end will be the one that is being included/extended.
sspvirgo
« Reply #2 on: July 21, 2011, 11:39:37 pm »
yes on the target end there would be the use case but how can we know whether it is included or extended. I am not able to get that information
sspvirgo
« Reply #3 on: July 22, 2011, 06:53:24 am »
i got it i use the connectors.stereotype that gave me the includes and extends value when the connectors.type = UseCase  and from there i was able to find out the extended and included use cases using the supplier id and client id attribute.
« Reply #4 on: July 22, 2011, 09:28:40 am »
Safer to check Connector.Subtype (possible values: "Extends" or "Includes")
