Author Topic: EA with repositories on PostgreSQL  (Read 6109 times)
Boron
« on: October 14, 2016, 11:40:42 pm »
we are having all our EA models on a PostgreSQL server.
The server is configured to have a login role named "ea_user" that has superuser rights as role privileges.
EA uses "ea_user" and its configured password to login into the database(s).
I feel a little bit uncomfortable for a long time with the superuser rights to "ea_user".
What kind of access rights or privileges does a login role need as minimum for being able to do all possible tasks when EA connects to the database using that login role?
If reasonable possible I would like to cut the number of access rights of "ea_user" to the minimum.
Re: EA with repositories on PostgreSQL
« Reply #1 on: October 15, 2016, 02:11:57 am »
R/W/U/D on rows is enough. You don't need grants for manipulating tables. But the tables needed for EA must be fully accessible for an EA user.
Boron
« Reply #2 on: October 17, 2016, 06:35:24 pm »
I assigned the following privileges now:
  • Insert (= write = W?)
  • Select (= read = R?)
  • Update (= U?)
  • Delete (= D?)
As far as I can see, I can work without any problems now.
I assume my mapping of "R/W/U/D" to the privilege names of PostgreSQL is OK. Can anyone confirm this, or was I just lucky :).
« Reply #3 on: October 17, 2016, 08:27:57 pm »
That's what I meant and you should be fine with these settings.
Boron
« Reply #4 on: October 18, 2016, 12:43:35 am »
Thanks a lot for your help :).
