Author Topic: Use Case - How to delete entry point in structured specification  (Read 11057 times)
UszynioO
I have use case, which have some entry points (for alternative scenarios) that are no longer needed, but I can't find any way to delete them from the model permanently. I can only remove them from use case, but they are still visible on the list of entry points avaliable for a scenario step. To make things worse, alternative scenarios refering to that entry points generate in documentation although they are removed from scenarios list.
I would really appreciate your help.
Re: Use Case - How to delete entry point in structured specification
« Reply #1 on: October 20, 2016, 08:46:37 pm »
Select the main scenario and then right click on the entry points at the bottom part.
You should then see an option to remove the entry point.
If this all doesn't work you might want to run a project integrity check.
UszynioO
« Reply #2 on: October 20, 2016, 08:48:57 pm »
OK, thx. I realized I can just switch to 'description' tab and delete it from there which results in removing it entirely from the model.
