Author Topic: XMI Export for Communication Package  (Read 6775 times)
« on: October 24, 2016, 08:19:58 pm »
Hello everybody,
we have a Problem with the Export from communication package (from SQL DB) to *.xmi file. We have defined collaboration Messages in the package, but the Export does not include this objects and so after the Import in the new Project (SQL DB) we miss this Messages. Does someone know where the problem is and how we can fix it?
Thank you for your help.
Anton
« Last Edit: October 24, 2016, 09:03:10 pm by [email protected] »
Re: XMI Export for Communication Package
« Reply #1 on: October 24, 2016, 08:54:58 pm »
Anton,
There is a known issue with the xmi export when using classes on sequence diagrams.
To avoid that problem you should always use instances.
I'm guessing the same applies for collaboration diagrams
« Reply #2 on: October 24, 2016, 09:17:39 pm »
Hi Geert,
thanks a lot. This is the solution. We've tested and it works.
Thank you very much
best regards
Anton
