Author Topic: Import from Visio  (Read 6033 times)
BobbyT
Import from Visio
« on: October 25, 2016, 06:41:49 am »
I have to  imported lots of  Visio diagrams using the MGD add on
we have already defines artifacts and specific network Vlans , firewall objects in our custom MDG technologies package
the import  creates its own Nodes under the newly created package
I was wondering if I can customize the import to point to already existing objects
I was trying to find a support number to call for USA or Canada  ( I am based in Toronto , Canada)  but there is only 1 no available for Australia If I'm not mistaken
I have send an email to support SparkX no answer yet
Please advice
Bobby
Re: Import from Visio
« Reply #1 on: October 25, 2016, 06:11:24 pm »
Bobby,
There is no telephone support from Sparx Systems directly, but you can contact a Value Added Reseller in your area who might be able to help you. See http://sparxsystems.com/partners/vars/north_america.html
With regards to your actual question. I don't have experience wit the visio importer, but I'm pretty sure it will not be able to overwrite existing elements, but only create new elements.
If you need a feature like that you could consider writing your own import script (or contact a VAR to write the script for you).
Should not be too hard I think.
If you are looking for a place to start you can use my simple Excel VBA importer
BobbyT
« Reply #2 on: October 26, 2016, 01:57:47 am »
the import creates the diagram and its own elements or nodes , like firewall , network
we already have these defined as common elements
I want to see how I can link the diagram with the existing objects
A VAR will charge us too much they already had one before
worse comes to worse I guess I can just import the diagram and maybe I can link to the existing common infrastructure objects
« Reply #3 on: October 26, 2016, 09:46:51 am »
If i't a one-time job and not too repetitive: do it manually. If it's to be done one a permanent basis, look into scripting it. You can use stereotypes for the shapes and set them to rules you need to figure out. If you can't afford a consultant, you have to learn that yourself. Depending on your abilities it may or may not pay out in the future ;-)
BobbyT
« Reply #4 on: October 28, 2016, 04:43:07 am »
It is repetitive tens of diagrams with tens of server .... importing will create new elements
I already have a place  Custom Infrastructure Elements where most of the subnets , servers and other objects are already defined in older projects
I want to import the Visio diagrams and write a script to point to already existing objects
regards
BObby
« Reply #5 on: October 28, 2016, 06:49:46 am »
That's probably the best approach then. If you run into issues, just come back here. I don't know how the visio importer works. But maybe if it can import in a new folder, you might set up rules to match existing elements from previous imports. This could be a naming convention and/or additionally a path and if that's possible some tagging.
