Author Topic: MDG - Diagram profile options not applied  (Read 8432 times)
Guillaume
    • www.umlchannel.com
« on: October 26, 2016, 08:07:31 am »
I created an MDG Tech with a UML and Diagram profiles. In the diagram profile, I needed to hide the stereotypes so I set Features - Show stereotypes = False and Elements - Hide Element Stereotypes = True.
In the target EA project where the MDG has been imported, I created a diagram. Unfortunately the hide stereotypes properties on elements and features are not set as expected.
Is it a bug?
Guillaume
Re: MDG - Diagram profile options not applied
« Reply #1 on: October 26, 2016, 10:24:28 am »
Is it a bug?
Possibly, Guillaume...  I have a related anomaly.  I set a diagram type n the Templates package to have "don't show Namespace", but when I create a diagram of that type that setting was not carried through correctly.   Possibly the same code fragment may be involved?
My understanding was that if you set such properties in the Templates Package (and MDG) they would be applied when you create a new diagram.
Glassboy
« Reply #2 on: October 26, 2016, 01:02:09 pm »
Did you guys use the profile helper or hand roll it?
Guillaume
« Reply #3 on: October 26, 2016, 04:11:46 pm »
I used the Profile Helper and the information can be found in the generated MDG XML file:
<Apply type="Diagram_Logical">
<Property name="pdata" value="HideStereo=0;HideEStereo=1;"/>
I'll report it as a bug.
Guillaume
« Reply #4 on: October 26, 2016, 04:45:39 pm »
The help says "HideEStereo=0; (to show element stereotypes in the diagram)" but it doesn't say "HideEStereo=1; (to hide element stereotypes in the diagram)" so it isn't necessarily the case. Try again with the property completely absent.
« Reply #5 on: October 26, 2016, 05:12:36 pm »
Classic EAUI?
Guillaume
« Reply #6 on: November 03, 2016, 05:29:17 pm »
This has been identified as a UI bug:
In the Profile Helper, the HideStereo option is incorrectly labelled "Show Stereotypes" and therefore works the wrong way around. The option works but the expectation is wrong.
We will get this fixed.
So applying the opposite for the Features in the profile helper resolves the problem in the meantime (Elements properties work fine).
Guillaume
