Author Topic: UML2 import broken in 13?  (Read 6696 times)
Giu Platania
  • As Above so Below
    • Linkedin
« on: October 28, 2016, 07:50:23 am »
hello forum,
today I had a bad surprise: EA was unable to import my UML2  file (eclipse format).
To be sure I tried with a file that I already imported in the past: nothing happens, after that you click the import button. Can anyone confirm this?
Giuseppe Platania
Enterprise Architect
Door Business Consulting
"As above so below, to accomplish the miracles of the One Thing" - Trismegistus
The above content reflects my own opinion and is not endorsed by Monthy Python
The above is NOT a reference to Monty Python
Giu Platania
  • As Above so Below
    • Linkedin
Re: UML2 import broken in 13?
« Reply #1 on: October 28, 2016, 11:22:45 pm »
on a separate machine I uninstalled 13, reinstalled 12.1 and tried with the same model.
No luck.
I'm quite sure that with 12.1 the XMI UML2 import was still working.
Can anyody confirm this?
Giuseppe Platania
« Reply #2 on: October 28, 2016, 11:38:39 pm »
Which of the formats do you use? Publish lists a dozen of them.
Giu Platania
  • As Above so Below
    • Linkedin
« Reply #3 on: October 29, 2016, 02:09:44 am »
Hi qwerty,
I'm trying to import an Eclipse UML2 file into EA as defined here:
http://www.sparxsystems.com/enterprise_architect_user_guide/12.0/projects_and_teams/import_emxuml2_files.html
Giuseppe Platania
« Reply #4 on: October 29, 2016, 03:08:45 am »
I'm terribly sorry, but I don't see those options. Using Corporate. The help does not indicate which edition you need or if a MDG is needed.
Giu Platania
  • As Above so Below
    • Linkedin
« Reply #5 on: October 29, 2016, 05:58:01 am »
So if you right click on package and selct import XMI you don't see the "other XMI"? Interesting. In comparing editions sparxt http://www.sparxsystems.com/products/ea/compare-editions.html  says tha XMi import export is available starting from desktop since version 7.0
Giuseppe Platania
« Reply #6 on: October 29, 2016, 06:24:33 am »
My bad. It can't export this format, only import. And I don't have a suitable source file.
Graham_Moir
« Reply #7 on: November 02, 2016, 05:51:52 am »
May be you should submit a formal support ticket?
