Author Topic: RAS timestamps  (Read 4520 times)
Uffe
RAS timestamps
« on: October 28, 2016, 07:28:56 pm »
Hi all,
Got another quite amazing pair of bugs in the reusable asset service in 11.1, which I'd like to know if they're still around in 12 and 13 before I file a report. You'd think these are so atrocious that there's no way they haven't been fixed, but then again they made it through Sparx' quality control in the first place, so worth a check.
Simply put, the timestamps in the Reusable Asset Service window are out of joint.
In the Registry Browser tab, there's a Last Registered column. This shows not the time each package was last uploaded, but the last time the tab was refreshed. You can verify this by hitting the green-arrows "Reload Registry Browser" button up top. Every row shows the same time.
Asset Properties has two fields Created Date and Modified Date. These show not the created and modified dates of the selected package, but the last time the selection was changed in the Registry Browser. Both fields show the same time.
So clearly a bit of demo code found its way into production. You 12/13 users, and how I envy you, could you check if this has been fixed?
Cheers,
/Uffe
Uffe
Re: RAS timestamps
« Reply #1 on: November 18, 2016, 07:48:14 pm »
I have reported this, and received the reply that it is no longer an issue.
