Author Topic: Change language of all elements of a package  (Read 19036 times)
jepessen
« on: October 31, 2016, 05:03:19 am »
Hi.
I've a project where there are many uml classes inside a package. The problem is that the language is wrong for all of them. I have to change classes language from Java to C++ for all of them. How can I automate this task without changing every class manually (they are almost 500)?
Re: Change language of all elements of a package
« Reply #1 on: October 31, 2016, 06:33:10 am »
You can do that either with a SQL or a script (executing the SQL or using the API):
UPDATE t_object SET genType="C++" WHERE genType='Java
I you want to do that for a single package you could add a WHERE clause for the packageId or extract the package with XMI and change it either in the XMI with an editor or imported in a dummy repo.
jepessen
« Reply #2 on: October 31, 2016, 07:28:39 am »
Thanks I'll try it.
« Reply #3 on: March 29, 2017, 09:20:00 am »
A low tech way is to export the package, make the change with an editor (I use Notepad++) and import it.
« Reply #4 on: March 29, 2017, 09:25:02 am »
I missed this first time around or I would have mentioned that you can do it with the UI: Right-click package in Project Browser > Code Engineering > Reset Options for this Package.
« Reply #5 on: March 29, 2017, 10:57:42 am »
This is the way IU do it, but recently, I've noticed that new items don't seem to get the language defined for the package - they get "<none>".  Should they?  I get EA to reset all the defaults and looking at the package it has the correct language.  BTW, the language is a non-standard one ("Conceptual")
« Reply #6 on: March 29, 2017, 01:27:35 pm »
Paolo, there is no option to propagate the language from a package to the elements created within it. A diagram type can specify a language, but not a package.
« Reply #7 on: March 29, 2017, 06:19:05 pm »
Learn something new every day!
You can specify it on each individual diagram.
However, there seems to be a bug.  If I set the language to <none> in the Diagram | Elements dialog I don't get "<none>" on a new element.  A specific language seems to work OK.
« Reply #8 on: March 30, 2017, 08:22:29 am »
Selecting '<none>' is the only way to specify that this diagram doesn't specify a language (and that the model default should be used.)
« Reply #9 on: March 30, 2017, 09:46:12 am »
Out of curiosity: why is it, that a diagram is related to a certain language? Seems like a coincidental choice.
« Reply #10 on: March 30, 2017, 10:57:45 am »
That's what I suspected, Simon.  But I couldn't find, in the new UI, where to set the Repository default.  Can you please enlighten me?  Also, since I can't see it, I can't check if "<none>" is an available option for the reposiotory default.  I believe it should be.
Aaron B
« Reply #11 on: March 30, 2017, 12:15:42 pm »
In EA 13 - Configure > Model > Options > Source Code Engineering : Default Language for Code Generation.
http://sparxsystems.com/enterprise_architect_user_guide/13.0/model_domains/code_generation_options.html
« Reply #12 on: March 30, 2017, 02:02:37 pm »
In EA a diagram specifies a profile being used by specifying the default toolbox. As a result it made sense when adding profiles for different programming languages that the same mechanism used to control the elements and stereotypes available controlled the language.
« Reply #13 on: March 30, 2017, 03:17:10 pm »
Ahh...  EAUI!   I was using the old Ctrl+F9 dialog and couldn't find it under Source Code Engineering!
The new UI puts up a similar looking, BUT DIFFERENT dialog.
« Reply #14 on: March 30, 2017, 06:51:07 pm »
Thanks Simon. that seems to make sense.
