Author Topic: XSLT Processor?  (Read 7872 times)
XSLT Processor?
« on: November 03, 2016, 05:39:29 am »
Hello!
May I ask if I write a tool using xslt for ea, which XSLT processor is used by the EA Sparx to execute it?
Thank you!
Kind regards,
Iryna
Re: XSLT Processor?
« Reply #1 on: November 03, 2016, 06:14:41 am »
I don't understand the question. EA does not use any XSLT, you just stuff XMI into it.
Re: XSLT Processor?
« Reply #2 on: November 03, 2016, 08:50:47 am »
The Publish XMI dialog has an option to specify an XSLT to adjust the generated XMI. The result is processed using msxml. The same applies to the publish and import scripts that can be added to an MDG technology.
There is also a debug XSLT option that uses xerces-c.
PS. qwerty, none of these options are new.
Re: XSLT Processor?
« Reply #3 on: November 03, 2016, 09:57:16 am »
Likely  :-[ But that's obviously a track I was not aware of.
