Author Topic: Sequence Diagram  (Read 5330 times)
John Espitia
Sequence Diagram
« on: November 04, 2016, 06:43:20 am »
Anyone have some information about generate sequence diagramas using Model Transformation? or some information or webpage to read about that?
Re: Sequence Diagram
« Reply #1 on: November 04, 2016, 07:07:44 am »
May this is possible, but I don't think it makes sense. Transformation is intended to perform a static structure transformation. It can't know how things collaborate. Maybe if you implement a rule interpreter it can create SDs. But then again, what's the use of it? SDs are used to show how collaboration works in complicated conditions where a couple of human brains have discussions on the hows and whens.
« Last Edit: November 04, 2016, 10:08:18 pm by qwerty »
bheggsum
« Reply #3 on: November 04, 2016, 10:11:31 pm »
This is about converting SD and CD to each other. They show the same thing in different ways. Again here: why? You create both diagrams with different intention. Now having the same thing shown in two ways duplicates work, since you have to maintain both diagrams when you make changes.
« Reply #4 on: November 05, 2016, 06:04:09 am »
I don't see how a transformation would help. What is your intention here?
