Author Topic: newest version of Enterprise Architekt 13 Crashes after standby (on Windows 10)  (Read 5494 times)
tobiass
I get this message when I wake up my computer:
Version 13, 0, 0, 1307
[Window Title]
Enterprise Architect - UML Development Tool
[Main Instruction]
Enterprise Architect - UML Development Tool funktioniert nicht mehr
[Content]
Das Programm wird aufgrund eines Problems nicht richtig ausgeführt. Das Programm wird geschlossen und Sie werden benachrichtigt, wenn eine Lösung verfügbar ist.
[Debuggen] [Programm schließen]
You should report that kind of errors to Sparx (link bottom right). Would be interesting to know if the same happens with V12. You can install both side by side by renaming the current EA programs folder to EA13 and running the V12 installer. After that you can rename EA to EA12 and EA13 to EA. You can then start V12 from the folder (the start menu will refer V13 then).
Please do send in a bug report.
I am aware of one other user reporting an issue with standby on Windows 10, but they haven't responded to our requests for more information.
Guillaume
    • www.umlchannel.com
I'm running EA 12.1 and since I moved to Windows 10, I'm getting issues with the standby mode.
When resuming, I'm getting a Busy Application popup with the action to retry ; I need to click several times before EA works again.
Guillaume
