Author Topic: Copy Relations  (Read 4693 times)
progress
Copy Relations
« on: November 15, 2016, 01:44:05 am »
Does anyone know if it is possible to copy relations from one object to another object?
For example we have an application artefact that is used/referenced by serveral other applications.
Then we make a company to create a new version, in this case version 2. Once we want to release Version 2, we would need to move the references from the artefact Version 1 to Version2. Is this possible without having to manually check and duplicate the relations?
Regards
Re: Copy Relations
« Reply #1 on: November 15, 2016, 02:35:12 am »
Do you mean copy or move?
In case of copy you'll have to make a new relation using Element.Connectors.AddNew() and copy the details from the original relation.
In case of a move you just have to update the source and/or target ID.
progress
Re: Copy Relations
« Reply #2 on: November 15, 2016, 08:08:17 pm »
What I meant is the second case "In case of a move you just have to update the source and/or target ID"
I guess there is no way of doing this semi-automatic? In some cases we have a large ammount of links and they are spread over mutiple diagrams.
Regards
Re: Copy Relations
« Reply #3 on: November 15, 2016, 09:29:20 pm »
Semi-automatically would mean you have to write a add-in. That's likely possible in your case. Just hire Geert ;-)
