Author Topic: Location of element description in DB  (Read 3849 times)
tzafrir
« on: November 16, 2016, 04:55:59 pm »
Does anybody knows where the description part of the element exists on DB?
Tzafrir
Uffe
Re: Location of element description in DB
« Reply #1 on: November 16, 2016, 06:04:17 pm »
Hi Tzafrir,
Elements are stored in t_object. The description (Notes field) is in t_object.Note.
However, if you're using EA's built-in SQL client ("Find in Project") it omits that column for some reason. But you can force it by renaming the column in the output.
Code: (SQL) [Select]
select Name, Note as Notes
from t_object
where something something
/Uffe
« Reply #2 on: November 17, 2016, 08:49:39 am »
Try clicking on the button and selecting 'View Notes' | 'Full Notes' instead of aliasing the Notes field. (http://www.sparxsystems.com/enterprise_architect_user_guide/13.0/model_navigation/search_view.html)
