Author Topic: EAV13 SysML: adding properties to blocks is still very inconsistent and tricky  (Read 4222 times)
PeterHeintz
On a SysML BDD or an IBD you can add properties to a block with some but not all allowed stereotypes (just prop, connector prop, distributed prop, flow prop,…). However you can set the right stereotype afterwards.
On the process browser you can only add a flow prop. But again you can change the stereotype afterwards again.
A more consistent solution would be, to allow adding the same subset of stereotyped properties or even just an “unstereotyped” property for both diagrams and project browser.
Even trickier e.g. it goes, when you want to have a “ClassifierBeaviourProperty” classified with a State Machine. If you have already a property and you want to classify it with a state machine you are not able to, because StateMachines are not shown as possible Property Types (presumably a bug). The only way by achieving that is by dragging and dropping the state machine to the block in the diagram and by selection “Property” in the dialog.
Best regards,
Peter Heintz
