Author Topic: Common Text Element  (Read 8170 times)
LClarke
Common Text Element
« on: November 24, 2016, 07:43:24 pm »
We are using the shared version of EA 13 however someone has somehow set the text element found in the common part of the toolbox, to add a hyperlink to part of a model every time rather than give us a text box.  I've been searching help to undo this but can't find anything.  has anyone got any ideas?
PeterHeintz
Re: Common Text Element
« Reply #1 on: November 24, 2016, 07:54:18 pm »
Do you mean "Note"?
Best regards,
Peter Heintz
LClarke
« Reply #2 on: November 24, 2016, 08:26:12 pm »
Its the "A" in the common toolbox and the bottom left corner of EA calls it a Text Element when I hover over it
PeterHeintz
« Reply #3 on: November 24, 2016, 08:32:46 pm »
Does that occur in any toolbox or in a specific toolbox?
Best regards,
Peter Heintz
LClarke
« Reply #4 on: November 24, 2016, 10:11:02 pm »
I've tried a few different toolboxes but the Common Toolbox doesn't change when you change toolboxes.  Its the A in the common toolbox from the example Image below
« Reply #5 on: November 24, 2016, 11:07:22 pm »
I could only imagine that an add-in is running out of order. Try to disable all MDGs and see what happens.
LClarke
« Reply #6 on: November 25, 2016, 12:22:00 am »
I disabled all my add-ins and restarted EA but the problem still persists
We are using a shared Server model and all have the problem (8 users)
PeterHeintz
« Reply #7 on: November 25, 2016, 12:47:17 am »
Did you also disable MDG's?
Best regards,
Peter Heintz
LClarke
« Reply #8 on: November 25, 2016, 01:02:42 am »
Yes I disabled the MDGs as well and it made no difference
« Reply #9 on: November 25, 2016, 07:54:25 am »
Does it happen with a plain new EAP? Or just with a certain repository. For all users or just certain users?
« Reply #10 on: November 25, 2016, 09:12:03 am »
I suspect somebody has set up a Project Template Package. Find the package, find the text element, delete the text element. :)
« Last Edit: November 25, 2016, 02:31:31 pm by KP »
LClarke
« Reply #11 on: December 01, 2016, 01:07:57 am »
Thanks that resolved
