Author Topic: Doc generation template - External requirements of element sorted by alias  (Read 5013 times)
albert
Is there a way via doc generation template only (no scripts) to get the External requirements of an element in the output document sorted by alias ?
Thanks in advance
Albert
Re: Doc generation template - External requirements of element sorted by alias
« Reply #1 on: November 26, 2016, 12:53:25 am »
If you only need some specific fields then then you could use an SQL fragment.
That won't work if you need diagrams or something like that.
albert
« Reply #2 on: November 26, 2016, 09:01:19 pm »
Thanks Geert for your reply,
It is indeed the case, I need linked docs and child elements. I will then use the script solution.
Best regards,
Albert
