Author Topic: API to compact a .EAP file.  (Read 7158 times)
« on: November 29, 2016, 12:27:13 pm »
A quick search of the forum suggests there is not an API call to directly compact a repository from EA.
I couldn't find one in the Help system.
Is that correct?
Re: API to compact a .EAP file.
« Reply #1 on: November 29, 2016, 09:43:18 pm »
I'd guess so. But that's Mickeysoft functionality. There might exist official APIs to compact an Access file.
« Reply #2 on: November 30, 2016, 10:27:07 am »
Yes, I can do it by spawning a subprocess to use Access to compact (we already spawn ZIP to create a compressed archive), but it's a lot of work for functionality that's already in already in EA - just not accessible (pun intended).
Glassboy
« Reply #3 on: November 30, 2016, 12:04:56 pm »
My assumption would be that it isn't in EA at all, but EA calls the API for the data layer.  The method might be called something like JetCompact for example.
« Reply #4 on: November 30, 2016, 08:25:09 pm »
Most likely. But of course it would be more convenient if the AP could provide the manual methods in its API.
Eamonn John Casey
« Reply #5 on: December 07, 2016, 03:18:04 am »
To do this you need to rename the local EAP file to MDB (Microsoft Access Database).
In under ODBC Data Sources (Start -> ODBC), select Microsoft Access as the your User Data Source. Click on the Select button to find your database¨. Then click on the Compact button. Job done.
Rename MDB back to EAP so Enterprise Architect can find it.
Eamonn J.
Eamonn John Casey
« Reply #6 on: December 07, 2016, 03:20:45 am »
Amend:
ADO and DAO APIs for Microsoft access provide compact functionality if you want to do this programmatically.
For example: http://stackoverflow.com/questions/3503736/access-compact-and-repair-programatically
