Author Topic: Error when calling Addin  (Read 4057 times)
mark.tootell
« on: August 15, 2011, 07:13:29 am »
Hi all
The C# addin I wrote to provide me with the utility functions I needed to generate my c++ code via the code generation template (see previous posts) is generating an error:
An error occurred while attempting to communicate with an addin:
CS_Addin(CS_Addin.Main)
"GetSignals: Invalid Parameters"
The Addin function that I am calling is declared as:
public object GetSignals( EA.Repository Repository, object[] args)
       object retObj;
       // Does stuff with strings
       return retObj;
and I call the Addin function from within the code generation template like this:
$opCode = %EXEC_ADD_IN("CS_Addin", "GetSignals", classGUID, classStereotype, ...)%
Can anyone tell me what I am doing wrong? and more to the point how I can fix it?
Mark
Re: Error when calling Addin
« Reply #1 on: August 16, 2011, 04:26:11 pm »
Mark,
The error says "invalid parameters"
Your operation requires a parameter of type EA.Repository, but I don't see you passing that anywhere (or is that done by EA?)
Isn't there somewhere  simple example available?
mark.tootell
« Reply #2 on: August 17, 2011, 05:27:08 am »
Hi Geert
Yes, the repository is passed by EA when the add-in function is called. Sparx support has come back with the solution. The function parameters needed to be as follows:
object GetSignals( EA.Repository Repository, object args)
The square brackets have been removed - simply as that.   :-?
Regards
Mark
