Author Topic: Project Transfer Automation  (Read 6910 times)
« on: December 15, 2016, 07:04:48 pm »
we manage our EA Models in SQL Database and transfer thw different models every day to eap file. Is there away to do the project transfer via batch/skript to automate the database transfer into eap file?
Thanks a lot for some ideas.
best regards
Anton
Re: Project Transfer Automation
« Reply #1 on: December 15, 2016, 08:33:10 pm »
« Reply #2 on: December 15, 2016, 08:39:21 pm »
You can run a vbs script as a scheduled task
A client of mine uses the following code in  vbs file:
Just make sure you run the taks with an actual user logged in.
sub main
Dim CurrentDate
Currentdate = Replace(Date, "/", "-")
dim repository
dim projectInterface
set repository = CreateObject("EA.Repository")
Dim FileName
Filename = "EA_Export.eap"
dim LogFilePath
LogFilePath = "C:\EA\EA_to_EAP.log"
dim TargetFilePath
TargetFilePath = "C:\EA\EA_Export.eap"
dim eapString
eapString = "EAConnectString:DB_EA_PROD --- DBType=1;Connect=Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security Info=False;Initial Catalog=DB_EA_PROD;Data Source=BESQLCP;LazyLoad=1;"
'get project interface
set projectInterface = repository.GetProjectInterface()
projectInterface.ProjectTransfer eapString, TargetFilePath, LogFilePath
'repository.CloseFile
repository.Exit
Dim newFilename
newFilename = "C:\EA\EAP_Files\EA_Export_" & CurrentDate & ".eap"
Dim Fso
Set Fso = WScript.CreateObject("Scripting.FileSystemObject")
Fso.MoveFile "C:\EA\EA_Export.eap", newFileName
end sub
main
