Author Topic: V12 vs. V13 Hyperlink Format  (Read 4125 times)
Gayle
« on: December 16, 2016, 10:51:34 am »
I'm reviewing how my architecture model looks when opened using EA V13 Build 1307.  The EA 12 Build is 1230.  So far, the only thing I'm seeing as a difference is with the formatting of Hyperlinks.  Most of my hyperlinks have an image assigned so that they look like a button.  There are a few that put a box around the hyperlink element and filled that box with a color using the default appearance functions.
I have captured some examples that can be sent, but I do not have the ability to insert them in this message.  In EA12, the "Change Records" and "Issue Records" hyperlinks have a black border and yellow/tan fill.  In EA13, the elements have those same appearance characteristics under default appearance, but they do not display with the border or fill.  I did a test to see if I could create a new hyperlink and format it with the same result (default appearance indicates border and color applied and display does not have them).
Is this a problem with V13 or do I need to update some setting that did not translate when moving from V12 to V13?
Gayle
Re: V12 vs. V13 Hyperlink Format
« Reply #1 on: December 19, 2016, 09:49:57 am »
I can't think of any intentional changes to hyperlink rendering.
I recommend sending the examples you have directly to Sparx Systems via the support links at the bottom of this page.
