Author Topic: EA13 + SysML: show port classifiers & property binding  (Read 4229 times)
Guillaume
    • www.umlchannel.com
« on: December 21, 2016, 07:29:40 pm »
I found a new diagram option under Elements in EA 13: show port classifiers.
This would be useful however I cannot get it to work.
I created a simple SysML BDD with a block + port, and set the port's classifier to a block.
The classifier is always visible, whether the option is disabled or enabled.
I also noticed the following announced improvement: "Part name change will now update bound Association role". However when renaming the part in the IBD, the association end role for the aggregation is not modified. Renaming the association end rolename updates the part but this is available in 12.1 already.
I'm running the latest 1309 build.
Guillaume
Helmut Ortmann
Re: EA13 + SysML: show port classifiers & property binding
« Reply #1 on: December 22, 2016, 05:38:38 pm »
I also have the problem of not seeing the type of a port property. You may change the default to always see the type by:
With,
- Start, Preferences, Object, Port and Part type visible by default
Please, don't forget to post a bug report!
Kind regards,
Helmut
Guillaume
« Reply #2 on: December 22, 2016, 06:23:43 pm »
Hi Helmut,
This is indeed a default setting I'm using.
I'll report the above as a bug.
thanks,
Guillaume
Guillaume
