Author Topic: SysML port size changes unmotivated  (Read 4006 times)
PeterHeintz
« on: December 22, 2016, 01:58:42 am »
When you have a port within a block and you assign a stereotype to it AND the stereotype changes the color appearance (in my case defined in a MDG) the default port size changes from 5mm x 5 mm to roundabout 20 mm x 30 mm.
A stereotype only defining change in color should not change the size! :'(
Best regards,
Peter Heintz
Re: SysML port size changes unmotivated
« Reply #1 on: December 22, 2016, 08:14:09 am »
You've probably exported the size of your stereotype element on the diagram as the size of of the stereotype. Explicitly specifying the size or unchecking the export of size should help.
