Author Topic: EA Query to find Implementing Interface Operation on Sequence Flow  (Read 4845 times)
potterm
In our design model we have sequence diagrams showing components receiving sequence messages.  The components do not have operations themselves, but implement interfaces defined within our model.  I want to write an EA query which returns the interfaces and the operations on those interfaces that are invoked by each sequence message on each sequence diagram.  However I don't know which table/attribute in the EA internal data model holds this information.
For example:
ComponentA implements Interface1 which specifies Op1, Op2 and Op3.  I have a sequence diagram which includes a message from another component invoking Op2 on ComponentA.  From my query I can see that the t_connector table contains an entry for this sequence with the name "Op2()", but I can't see how to navigate from there to find Interface1 and Op1 (i.e. which table/attribute holds the information).
I would expect it to be in t_connector, but nothing in that table seems to record the classifier and operation that is the target of the sequence message.  I know that EA holds this information because when I double click on the message in the diagram and select the message pull-down I can see the fully qualified name selected in the list (i.e. "Interface1::Op2").
Does anyone know?
Martin
Re: EA Query to find Implementing Interface Operation on Sequence Flow
« Reply #1 on: December 22, 2016, 04:16:01 am »
You find the relevant information in t_connectortag where the according operation GUID is stored. t_connectortag.ElementID is the connectorId.
« Last Edit: December 22, 2016, 04:18:23 am by qwerty »
potterm
« Reply #2 on: December 22, 2016, 04:46:36 am »
That did it  :)
Thanks very much qwerty!
