Author Topic: Sequence Diagram - Lifelines  (Read 6566 times)
zyx
« on: December 27, 2016, 10:34:44 am »
Dear all,
    Again I apologize for my bad english...
    I am modeling a sequence diagram and I have dragged a control class to the diagram. I set the control class instance as a lifeline and I set its stereotype as control. The only problem is that the name of the class appear to be too long and the ":" is showed a line above the name of the class... Can I configure the tool to change it?
Helmut Ortmann
Re: Sequence Diagram - Lifelines
« Reply #1 on: December 28, 2016, 01:06:27 am »
as far as I know, there is no possibility to customize this behavior.
You can:
- Avoid entering a stereotype for the object instance/lifeline
  Then you can resize it. But you can't easily see that's a controller.
- Use a name for the lifeline (may look better)
- Use spaces in name (may look better)
- Live with it
- Feature request
Kind regards,
Helmut
