Author Topic: Generating a report with 2 values, each from a diffrent query, in one fragment  (Read 5415 times)
tzafrir
hi,
The problem:
I am creating a report and I need to have 2 values (each from a different query) presented in one fragment
Is it possible to put 2 queries together in one fragment? If yes, can someone give a simple example what the correct way that it should be done because currently I am only able to put one.
Tzafrir
Helmut Ortmann
With SQL and also with a Model Script you can select an arbitrary information to visualize with your Template Fragment. Each column may be from a different model element or model element type. With SQL you accomplish this with e.g. "UNION".
There is also the possibility to use a Document Script to return rtf.
You find a description:
http://www.sparxsystems.com/enterprise_architect_user_guide/13.0/model_publishing/custom_query_fragments.html
Kind regards,
Helmut
tzafrir
Union does not work here as I need to extract diffrent values in each query.
This is more general question, is there option to put 2 queries together in 1 fregment.
There's only one query per sql fragment.
Union will still be possible, just explicitly put empty values in.
eg.
select Name, Stereotype, GenType, '' as AttType from t_object where Object_Type='Class'
union
select Name, Stereotype, '' as GenType, [Type] as AttType from t_attribute
It does make me think you should probably rethink what you are trying to do or the approach to it. eg. The template selector allows you to select a different template based on object type.
