Author Topic: Access EA via COM (Win 7)  (Read 5108 times)
TLutz
« on: August 22, 2011, 09:00:38 pm »
im trying to convert an Enterprise Architect model to an EMF model.
Therefore i have to access the EA via COM. This works quite well under Windows XP, but Windows 7 comes up with an error.
I accessed EA from Java as described in your tutorial via the files SSJavaCOM.dll and eaapi.jar.
http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/setup.htm
Under Win7 the expression "org.sparx.Repository r = new org.sparx.Repository();" raises the exception "Failed to construct object. Error code: 0x80040154". (There is no problem with XP)
Does anyone already have experiences with this?
Many thanks in advance!
Tobias
Im using Enterprise Architect Version 8.0.858.
Re: Access EA via COM (Win 7)
« Reply #1 on: August 23, 2011, 08:19:16 am »
Let me guess.
You're attempting to use EA from the 64 bit version of the JDK.
EA is only available as a 32 bit application, so you won't be able to do it.
TLutz
« Reply #2 on: August 23, 2011, 03:34:43 pm »
Yes, you are right, i have not realized this.
Tank you.
