Author Topic: Model Search Group  (Read 5642 times)
MatthiasVDE
Model Search Group
« on: January 03, 2017, 09:06:20 pm »
What's the purpose of scripts that are created in the Model Search Group? I can't find any explanation about this script group...
Re: Model Search Group
« Reply #1 on: January 03, 2017, 11:29:38 pm »
Those scripts are listed as searches in te model search. I believe there's an example somewhere in the learning centre or help, but I can't locate it quickly.
You'll have to make sure they return an xml string in a specific format.
MatthiasVDE
« Reply #2 on: January 03, 2017, 11:40:52 pm »
Thanks Geert, but at first sight there isn't any difference with the search group scripts, both are listed in the model search window.
Helmut Ortmann
« Reply #3 on: January 04, 2017, 02:01:41 am »
if you insert a script in the Model Search Group you can call the Script from Find in Project (CTRL+F) by:
- Right click on found item
- Scripts, Select one of the scripts
It gives you easy access to Scripts which run on found items.
Helmut
