Author Topic: RunReport from script  (Read 8208 times)
ja1234
« on: January 05, 2017, 01:48:43 am »
This code does NOT >:(  work:
var prj = Repository.GetProjectInterface();
prj.RunReport("{GUID}", "test","C:\\diagram_export\\3.rtf");
where test is a template in User Templates
I simply have hardcoded something in the "test" file and I want to export it into a rtf. Ideas why it is not working?
Re: RunReport from script
« Reply #1 on: January 05, 2017, 02:34:34 am »
At a guess: the GUID must be formatted with prj.GUIDtoXML (guid)
ja1234
« Reply #2 on: January 05, 2017, 03:32:55 am »
        var id = Repository.ProjectGUID;
var xmlID = prj.GUIDtoXML(id);
prj.RunReport(xmlID , "test","C:\\diagram_export\\3.rtf");
Thanks. Tried it, still not working. Everything that I put as arguments is simply ignored - the document generation window triggers with a totally different template name and path.  :o :o :o
« Reply #3 on: January 05, 2017, 04:20:06 am »
It helps if you read the explanation in the manual.
Simply guessing and throwing random stuff at the operations usually doesn't work.
http://www.sparxsystems.com/enterprise_architect_user_guide/13.0/automation/project_2.html
ja1234
« Reply #4 on: January 05, 2017, 08:39:24 pm »
Probabilistic programming and it can sometimes work , especially when the documentation is ambigous ;)
so, here's the deal:
- assume a package, that does not have the stereotype MasterDocument
- you want to RunReport on that package, from a script
Select the package in the Project Browser Window
then in your script add:
var currentProject = Repository.GetProjectInterface; //gets current project
var id = currentSelectedElement.PackageGUID; //gets currently selected package GUID
currentProject.RunReport(id, "Your_Custom_Template_Name", "C:\\exports\\1.rtf");
where Your_Custom_Template_Name is saved in Resources/User Templates
This works.
« Last Edit: January 06, 2017, 12:54:32 am by ja1234 »
« Reply #5 on: January 05, 2017, 09:35:00 pm »
I'm sorry, from your response I can't make out if you have solved the issue or still have a problem and you are requesting help.
« Reply #6 on: January 05, 2017, 10:37:00 pm »
I just tried the above snippet and had no issue creating a report.
ja1234
« Reply #7 on: January 06, 2017, 12:56:24 am »
Yes the snippet works, putting it out there for anyone who might have the same problem.
