Author Topic: Unable to set BPMN Gateway Parameters  (Read 5174 times)
Screwtape
« on: January 11, 2017, 08:21:46 pm »
Hi!
I've just tried to update the gateway direction BPMN parameter, on a BPMN gateway, and I can't see how to set the parameter. The parameters are displayed in the BPMN tab, but it does not allow me to update them.
Can anyone suggest what am I doing wrong?
Thanks!
Screwtape.
Screwtape
OpenIT Solutions
Re: Unable to set BPMN Gateway Parameters
« Reply #1 on: January 12, 2017, 10:42:51 pm »
Do you have security on your model ? It could be that the diagram is locked or you don't have permission to edit ...
Screwtape
« Reply #2 on: January 12, 2017, 11:33:56 pm »
Hi!
I don't have any security enabled as far as I know, as I'm using a local repository.
Thanks!
Screwtape.
Screwtape
Graham_Moir
« Reply #3 on: January 13, 2017, 04:31:00 am »
I just replicated the symptoms you've described by locking the element.  (Select the gateway, right-click, lock element).  Having done that I can still change the properties on the "Main" tab, but they are greyed out on the BPMN tab.  If I unlock the element, I can once again set the gateway direction.
You can tell if an element is locked in the project browser because it will have a red exclamation mark next to it.
