Author Topic: Addin enabled or disabled  (Read 5418 times)
Knut Paulsen
« on: January 13, 2017, 08:41:32 pm »
Hi guys,
Does anybody know where EA stores information about weather a given addin is enabled or disabled?
And is this setting per EA project or all or none?
br
Knut
Re: Addin enabled or disabled
« Reply #1 on: January 13, 2017, 09:44:06 pm »
At a guess: the registry.
P.S. But nothing obvious here. Try altering the setting and compare registries before and after. Also look for modified files in %appdata%
« Last Edit: January 13, 2017, 09:54:06 pm by qwerty »
Uffe
« Reply #2 on: January 13, 2017, 10:28:19 pm »
Hej Knut,
It's stored in the registry in HKCU\EA400\EA\OPTIONS\ExcludeAddins, which is a null-terminated string value (REG_SZ), which contains a comma-separated list of Add-In names, where I presume each entry matches one of the keys under HKCU\EA400\EAAddins.
The setting is client-global, so it affects all projects.
/Uffe
Knut Paulsen
« Reply #3 on: January 13, 2017, 10:38:57 pm »
Thanks Uffe,
found it :-)
br
Knut
