Author Topic: BPMN 2.0 process - how to create a sub-process?  (Read 7802 times)
Martin Lichtin
« on: August 25, 2011, 07:00:38 pm »
Can't figure out how to create a sub-process.. How is it done?
I'd expect a Task/Activity with a + sign it which I could click
to extend and edit its contents (or similar).
philchudley
Re: BPMN 2.0 process - how to create a sub-process
« Reply #1 on: August 26, 2011, 04:02:36 am »
Right-click and select Advanced | Make Composite  - this creates a linked BPMN Business Process diagram and displays the + sign
You may also change the TaggedValue activityType to Sub-process
Please note that in order to create a linked BPMN process diagram, you must make the activity a composite, just setting the tagged value merely displays the +
Cheers
Phil
Models are great!
