Author Topic: ShapeScript : hide name of element  (Read 6034 times)
bITs.EA
« on: January 19, 2017, 02:38:28 am »
Hi
I have a simple shapescript for a stereotype with metaclass "ObjectNode":
shape main
noshadow="true";
fixedAspectRatio="true";
SetFillColor(255,255,255);
defsize(20,20);
startpath();
moveto(50,0);
lineto(75,50);
lineto(50,100);
lineto(25,50);
lineto(50,0);
endpath();
//StrokePath();
FillAndStrokePath();
When I use this element, the shape is drawn as expected. BUT the name of the element is shown below the shape. How can I 'hide' the name?
Re: ShapeScript : hide name of element
« Reply #1 on: January 19, 2017, 10:55:02 am »
ObjectNode may use the Label subshape to render the name.  You can check by seeing if you can select the "label" and move it around.
Try:
Shape Label
    print ("");
to override the default Label Behaviour.
bITs.EA
« Reply #2 on: January 19, 2017, 08:48:22 pm »
Thanks Paolo! That's the solution indeed.
I just found the same answer in the MDG documentation :)
If you have an empty shape routine, it overrides the default; so, a blank 'shape label' prevents the creation of the
normal floating text label for elements that have them
My solution (same idea as Paolo's)
shape main {
// main code
shape label {
//empty label shape to prevent the name from showing on the diagram
