Author Topic: Need Help with JAVA API for Sparx EA  (Read 7978 times)
Risky
« on: January 21, 2017, 01:47:26 am »
Friends,
I'm absolutely new to Sparx EA and know Java.
I want to write a Java code to connect to an existing repository (which is in SQL db).
my use case is to find what package under a specific element was modified in last 24 hours.
I tried following, but am getting this error:
       org.sparx.Repository repo = new org.sparx.Repository();
       repo.OpenFile("Connection String to DB");
       System.out.println(Repository.class);
       repo.CloseFile();
error:
Exception in thread "main" java.lang.Exception: Failed to construct object. Error code: 0x80004002
   at org.sparx.Repository.comConstructor(Native Method)
   at org.sparx.Repository.<init>(Repository.java:190)
   at ConnectEARepo.main(ConnectEARepo.java:6)
Appreciate your help
Re: Need Help with JAVA API for Sparx EA
« Reply #1 on: January 21, 2017, 02:56:39 am »
Have you tried the simple case with a path to an EAP first?
Nabil
    • View My LinkedIn Profile Here
« Reply #2 on: January 23, 2017, 04:33:55 pm »
You can refer these
https://exploringea.com/2013/12/11/ea-automation-with-java/
Refer C:\Program Files (x86)\Sparx Systems\EA13\Java API
C:\Program Files (x86)\Sparx Systems\EA13\Code Samples\Java_Sample
BR
Nabil
Nabil
« Reply #3 on: January 27, 2017, 11:02:14 pm »
Java and EA are really not the best of friends.
If at all possible you better switch to C#
